smilepak
Aug 12, 2019Tutor
Netgear Orbi and ATT Pace 5268 Router
Using the Netgear Orbi, is using the Pace 5268 w/ DMZ+ better or using the Arris with IP Passthrough, which one would allow maximization of the 1gbps speed of the ATT fiber. The issue I am faced with...
Aug 12, 2019Guru - Experienced User
Others posted about this same model modem...
Does your ISP support a stand alone modem option? This would be prefferred over the gateway modem for use with the Orbi system.
smilepak
Aug 13, 2019Tutor
FYI for anyone who has similar problem. This fixed the slow download issue I am having between the Netgear Orbi and ATT Pace 5268. I am not getting the 800mbps that I get if connected directly to the ATT router, but I am getting 500-600mbps. Much better than what I was getting before.
https://forums.att.com/t5/AT-T-Fiber-Equipment/PACE-11-1-0-531418-DMZ-Issue/m-p/5745153#M7940
- FURRYe38Aug 13, 2019Guru - Experienced User
Good to hear. Glad it's working better now. Thanks for letting us know. Please mark your thread and solved so others will know.
Enjoy. :smileywink:
