truefan34
Jun 16, 2018Tutor
Netgear Orbi and setting up a Moca network...
I used to have Verizon Fios and the Quantum Router. I have gigabit internet, and now I just have internet service (so I know my coax is run and moca compatible).
I currently have the Netgear ...
Jun 16, 2018Guru - Experienced User
You might contact the Mfr of this adatper to see if it will work with home class routers...I presume it should work. You could hook up a external network switch that would help...
