truefan34
Jun 16, 2018Tutor
Netgear Orbi and setting up a Moca network...
I used to have Verizon Fios and the Quantum Router. I have gigabit internet, and now I just have internet service (so I know my coax is run and moca compatible).
I currently have the Netgear ...
GadgetVirtuoso2
Jun 16, 2018Apprentice
This is what I have setup at my house. Since I'm renting I couldn't run ethernet everywhere but I can use the COAX to hardwire things that can't be wireless. I've had this setup on two generations of Airport Extremes and now Orbi without an issue. I currently have AT&T FIber but I did have this setup when I had Frontier FIOS.
I'm using a pair of ActionTec Moca adapters ECB6200K02 and ChannelMaster 4 port adapter CM-6004. The ActionTec is connected to my Orbi.
If you have any COAX splitters make sure they pass the MoCA frequencies and you should be good.
- truefan34Jun 16, 2018TutorThat’s awesome news. So I don’t have to use my old quantum router. Sounds like I’m going this route and I’m ordering some adapters to try.
