truefan34
Jun 16, 2018Tutor
Netgear Orbi and setting up a Moca network...
I used to have Verizon Fios and the Quantum Router. I have gigabit internet, and now I just have internet service (so I know my coax is run and moca compatible).
I currently have the Netgear ...
GadgetVirtuoso2
Jun 16, 2018Apprentice
This is what I have setup at my house. Since I'm renting I couldn't run ethernet everywhere but I can use the COAX to hardwire things that can't be wireless. I've had this setup on two generations of Airport Extremes and now Orbi without an issue. I currently have AT&T FIber but I did have this setup when I had Frontier FIOS.
I'm using a pair of ActionTec Moca adapters ECB6200K02 and ChannelMaster 4 port adapter CM-6004. The ActionTec is connected to my Orbi.
If you have any COAX splitters make sure they pass the MoCA frequencies and you should be good.
truefan34
Jun 16, 2018Tutor
That’s awesome news. So I don’t have to use my old quantum router. Sounds like I’m going this route and I’m ordering some adapters to try.
