Kerrold
Nov 08, 2018Guide
Netgear Orbi and VPN
Hi Folks,
I am considering buying the RBK53 system, but wondering if it is possible to install / configure a VPN onto the router? The requirements of my VPN is the router supports Tomato or DD-...
quaningeneva
Nov 08, 2018Apprentice
You have to install another router in front of the Orbi to make this possible. This router has to support VPN client. ASUS has native firmware which supports VPN client on their routers. Alternatively, you can use ASUS compatible routers in mesh mode.
Kerrold
Nov 09, 2018Guide
Hi quaningeneva, I do have another router that my ISP gave me...so maybe I can install the VPN on there... will look at the model and see if that is possible. Thanks
KG
