AniDutta
Dec 12, 2016Apprentice
Netgear Orbi app
Finally after couple of months of launching the amazing hardware, Netgear came out with an app. Please don't get your hopes high with this app. It is an utterly useless app. The only functionality it ...
Retired_Member
Jun 19, 2017Netgear shut off their Jets and moved on to their next product release. Leaving all their users in the dust.
- peteytestingJun 20, 2017Hero
Retired_Member
sig , you know this is not the case ( as i have explained in other threads to you and others ) and continually trolling anmd complaining is tbh just making you look a little silly , just know the wheels may turn slow but they are still turning
- RobdogAug 27, 2017InitiateDid anybody switch from a Netgear to the Netgear Orbi? I did and the Orbi app doesn't do much but the older regular old Netgear app works to see what's on and what it's connected to. You can use some of the parental controls and a few other things. It's not perfect but the Orbi pushes out tons of bandwidth and the regular Netgear app works for most functions. I'd try that if I were y'all.
- RobdogAug 27, 2017InitiateHi, don't know if anyone else went from a regular Netgear router to the Orbi but I had one and had the standard Netgear app and it works pretty well about 80% functionality. Parental controls and the like. Yep the Orbi app seem like a placeholder but the regular app does most of what people are looking for. Guess the Netgear folks should have told us that but at least something works.
