AniDutta
Dec 12, 2016Apprentice
Netgear Orbi app
Finally after couple of months of launching the amazing hardware, Netgear came out with an app. Please don't get your hopes high with this app. It is an utterly useless app. The only functionality it ...
Retired_Member
Jun 19, 2017Netgear shut off their Jets and moved on to their next product release. Leaving all their users in the dust.
Robdog
Aug 27, 2017Initiate
Did anybody switch from a Netgear to the Netgear Orbi? I did and the Orbi app doesn't do much but the older regular old Netgear app works to see what's on and what it's connected to. You can use some of the parental controls and a few other things. It's not perfect but the Orbi pushes out tons of bandwidth and the regular Netgear app works for most functions. I'd try that if I were y'all.
