cfulbright
Aug 23, 2021Tutor
Netgear Orbi as simple Access Points to replace Apple Airport Expresses
I have a Netgear router with built-in WiFi that connects to my modem downstairs, and then an Apple Airport Extreme and two Airport Expresses that provide WiFi upstairs where all the living spaces are...
- Aug 24, 2021
Thank you, that's very helpful! My point-to-point IP provider (MonkeyBrains) is giving me 90 Mbps, so the 100 Mbps currently isn't a bottleneck. I may upgrade the router to that cool looking Nighthawk AXE11000 WiFi Router (RAXE500) at some point in the future, but waiting for it (hopefully) to come down in price. But the Ethernet cabling in the house also is 100 Mbps, so even then it may not be worth it.
I decided to go with the Nighthawk AX6000 WiFi Mesh Extender (EAX80) rather than the Orbi because with its four Ethernet ports it can replace my Airport Extreme as well as the two Airport Expresses. And if it has the range it claims, I won't need any other WiFi AP's.
CrimpOn
Aug 23, 2021Guru - Experienced User
cfulbright wrote:
A friend in IT recommended the Netgear Orbi and swears they can act as AP's without being a router. Before I go and spend $350 or more to buy some Orbis, I want to make sure I can easily swap out my Airport Expresses without a lot of fuss.
Yes, Orbi systems can be in Access Point (AP) mode, performing no routing functions, and will be totally integrated with the IP subnet of the primary router. Even if set to the same WiFi SSID/password, the Orbi WiFi network will be separate from the primary router network. (i.e. devices will not roam seamlessly between them.)
Orbi has many different product lines. The original 802.11ac Orbi (less expensive) has no support for 802.11ax (WiFi6) The AX models are considerably more expensive than the older models. If WiFi6 is important, the cost will be higher.
A number of users have reported swapping out Airport Express. One topic that has come up several times is attaching USB hard drives. Airport Express appears to support that (I don't have any to know personally). Orbi does not. It was on the original product design and very quietly disappeared, along with the physical USB port.
cfulbright
Aug 23, 2021Tutor
I have a Netgear Genie R6080 as my router. Would either the Orbi or the Nighthawk play nice with it?
- CrimpOnAug 23, 2021Guru - Experienced User
This is a seriously old router. I would replace it with a new WiFi system. Since you are already using several access points, it appears that a new mesh system would be appropriate. As far as what to buy, that's a really tough question. There are so many choices
- eero
- Asus
- Linksys
- TP-Link
- and two competing product lines from Netgear: Nighthawk and Orbi
I am very happy that I own zero products compatible with WiFi6 and will not be facing this decision for at least a couple of years.
- cfulbrightAug 23, 2021Tutor
I think my router's only three years old. Do you consider that to be "seriously old"?
Are you always this rude to people, or just to the people looking for help in a community? I hope your day job doesn't involve dealing with people.
I've been in software product management for over 30 years - probably before you were born. And I know my way around computers and networks, starting with MS-DOS, 3Com, etc. So stop the snarky attitude.
I assume you know that if I'd turned off the wireless radio on the eeros, I wouldn't have been able to communicate with them via my phone, which I was doing. What would be the point of having eeros or any WiFi device if you turned off the wireless radio?
I spent about five hours over several days with the eero support people (much nicer people than you are), and they couldn't get it to work the way I wanted within my existing network.
Seriously, please don't answer people's questions if you're going to be so rude. I'm sure you think you were making yourself look smart, but you didn't.
- FURRYe38Aug 24, 2021Guru - Experienced User
Yes you can add any router to what you are using now.
Just be aware that the R6080 LAN ports are 100Mpbs while newer more higher level routers have 1000Mpbs LAN ports. So the R6080 can be a bottle next in regards to this.
The R6080 is not old, just low end entry level router for people on budget.
- cfulbrightAug 24, 2021Tutor
I decided to go with the Nighthawk AX6000 WiFi Mesh Extender (EAX80) rather than the Orbi because with its four Ethernet ports it can replace my Airport Extreme as well as the two Airport Expresses. And if it has the range it claims, I won't need any other WiFi AP's.- FURRYe38Aug 24, 2021Guru - Experienced User
Ok kewl.
Ya I have a RAXE500, kinda nice. Still new to me though.
Ya if your lan cables are only 100Mbps, then you might consider upgrading when the time is seen in the future. CAT6 LAN cable is recommended.
Good on the EAX80. Seems to be a good unit. I only had one for a short time.Hope it all works out for you.
Good Luck.
