cfulbright's avatar
Aug 23, 2021
Netgear Orbi as simple Access Points to replace Apple Airport Expresses
I have a Netgear router with built-in WiFi that connects to my modem downstairs, and then an Apple Airport Extreme and two Airport Expresses that provide WiFi upstairs where all the living spaces are...
  • cfulbright's avatar
    cfulbright
    Aug 24, 2021
    Thank you, that's very helpful!  My point-to-point IP provider (MonkeyBrains) is giving me 90 Mbps, so the 100 Mbps currently isn't a bottleneck.  I may upgrade the router to that cool looking Nighthawk AXE11000 WiFi Router (RAXE500) at some point in the future, but waiting for it (hopefully) to come down in price.  But the Ethernet cabling in the house also is 100 Mbps, so even then it may not be worth it.
    I decided to go with the Nighthawk AX6000 WiFi Mesh Extender (EAX80) rather than the Orbi because with its four Ethernet ports it can replace my Airport Extreme as well as the two Airport Expresses.  And if it has the range it claims, I won't need any other WiFi AP's.
