Seamus12
Dec 29, 2020Tutor
Netgear ORBI drops when wired to PS5 and XboX
Happens every day Ps5 is wired Firmware is the latest v 2.7.2.102 Modem is ARRIS SURFboard SB6183 PS does not have WiFi broadcast It also happens with the Xbox which is also wired. Any he...
Dec 29, 2020Guru - Experienced User
Does this happen with both consoles are online or either one online?
What are other devices doing when this happens? Anyone else streaming or downloading anything?
Are the consoles wired directly behind the RBR?
What CAT# cables are you using? CAT6 is recommended.
What is your ISP speed package UP and DOWN that you pay for?
How many RBS are being used?
Has a factory reset and setup from scratch been performed since last update?
