Seamus12
Dec 29, 2020Tutor
Netgear ORBI drops when wired to PS5 and XboX
Happens every day Ps5 is wired Firmware is the latest v 2.7.2.102 Modem is ARRIS SURFboard SB6183 PS does not have WiFi broadcast It also happens with the Xbox which is also wired. Any he...
Seamus12
Dec 29, 2020Tutor
they're never both online at the same time. no one is ever streaming anything that I'm aware of.
cat6 cables are being used and they are wired behind the RBR.
my download/upoad speed is 470/23
i have 2 sat - RBS50 and RBW30
Dec 29, 2020Guru - Experienced User
Something to try and see, turn off the satellites and just run the RBR alone.
Might set up a IP address reservation for both consoles on the RBR.
You can try and set NAT Filter to OPEN and see if this does anything.
I've loaded v102 on mine and have two xbox 1s and will be checking mine out this evening. I don't have a PS or new X series.
This just happening after you got the PS5 wants to point to something on the console causing problems though....
- FURRYe38Dec 29, 2020Guru - Experienced User
This is interesting:
https://www.reddit.com/r/PS5/comments/k0wife/ps5_next_to_router_caused_major_dropped_packets/
- Seamus12Dec 29, 2020Tutor
oh wow. I'll move the ps5 and see if that's the culprit
I'm a total noob when it comes to setting up manually :/
ie. IP reservation and NAT filter set up
So under Advanced Tab/Setup/LanSetup.
Select the Add button, this will show you a list of devices that you can give a IP address reservation too, select the console to add, scroll to the bottom of that page to be sure the info is correct, then select ADD. Do this for both consoles. Then select Apply on the LAN setup page. The RBR should reboot here.
NAT Filter is here under Internet Setup:
- FURRYe38Dec 30, 2020Guru - Experienced User
FYI, I we gamed last nite with two xbox ones running behind the RBR in router mode v102 loaded. Zero issues while gaming. v102 seems solid at this point.
Hope you found something with your PS5...
