Mahed24
Jul 28, 2020Aspirant
Netgear Orbi Ethernet Conncection
Hi, I have a question on how Ethernet with the Netbear Orbi works. I want to set up my netgear orbi router in one room and the satellite in a different room. If I wanted to use a Ethernet connection f...
Mahed24
Do I have to connect the RBR and RBS together using a CAT6? I can’t just straight up use a LAN cable from an Ethernet port on the RBS to a PC, console, or TV that I’m using. Do I have to do a Ethernet backhaul before doing that? Sorry if I’m not making sense.
Jul 28, 2020Guru - Experienced User
No, if the RBS is wireleslly connected to the RBR, then you can connect a ethernet connected PC to the back of the RBS for internet access thru the RBS.
