nlewis20
Nov 27, 2017Aspirant
Netgear Orbi Ethernet connection drops
Every so often my PS4 that is hardwired back to the Netgear Orbi sattelite Ethernet port drops all connection. My Orbi has the latest firmware V 2.0.0.74. Why would it be dropping the Ethernet port connection? Could it be a bad Orbi sattelite? The connection back to the main router is good.
Sort By
- DarrenMSr. NETGEAR Moderator
First thing I would test is a new cable and even trying a different port on the orbi make sure its not a hardware issue.
DarrenM
- nlewis20AspirantSo I already tried replacing the Ethernet cable and port on the orbi. Still drops connection.
- Retired_Member
distance from Router to Sat...?
How did the PS perform using wifi?
