greattutor9000
Dec 07, 2018Aspirant
Netgear Orbi Keeps freezing
Hello,
I am having a weird problem with my NetGear Orbi(RBR50). My entire network will just freeze up for about 2-3 minutes and then it will go back to normal. When I say freeze up when I try to ...
Dec 07, 2018Guru - Experienced User
Try a full power OFF of the ISP modem and Orbi router for 1 minute. Then back on with the modem and let it sync. Then power ON the Orbi router.
Might try a factory reset of the Orbi router if your FW was autoupdated.
- greattutor9000Dec 07, 2018Aspirant
Hi,
Thanks for the reply, I powered of both devices and powered back on the modem and let it sit for about 5 minutes. THen I powered on the Orbi. Unfortunatly about a hour or so later I expereinced the same 1-3 minute freeze up of my network. I don't see any error messages or anything that could lead me to the problem
- ekhalilDec 07, 2018MasterWhat wired devices do you have connected to Orbi? Any wired mesh speakers (eg. Sonos)?
Well I have three unmanaged switches through out my home. One switch is connected to the hub while the other two are spread out in my home. I have a PC, some Amazon devices, two smart TV's and a XBOX unit. I have one switch dedicated to my home automation hubs (smarthings, Hue, and sonos). None of my Sonos speakers are hardwired.
