Asm221
Jun 10, 2021Aspirant
Netgear ORBI Login issues & Parental control ad
Hi I am continuously having issues with orbi Login Have had these in the past and the only solution has been to do a reset. Past 12 months have resetted it approx 6 times - Fed up with this ...
olympos1625
Jun 24, 2021NETGEAR Employee Retired
Hi Asm221,
Thank you for the information. We already endorsed your issue to our Level 2 department. They will get back to you on your preferred callback date and time.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
- Asm221Sep 12, 2021Aspirant
Hi Oliver
Your guy did not give me a call
I have been having pproblems with the orbi all morning today
To be honest am sick of it
Since my 20 year history with being with using netgear products I have so far found this to be the worst of them
I think my unit is a faulty one
Please can you take a look into this urgently or provide me details for the UK office so I can draft a letter in writing for a replacement
- FURRYe38Sep 12, 2021Guru - Experienced User
Please send olympos1625 Blanca_O a PM and make contact with them and get some help on this...
- CrimpOnSep 12, 2021Guru - Experienced User
Normally when an issue has been taken up by a forum moderator and referred to Netgear support, we 'ordinary folk' step back. (Often with feelings of, "how did he get so lucky?")
It is tempting to assume that the original issues described back in June remain the problem. Are they?
Is the goal of posting in the forum to seek advice from other users, or to contact the moderator? (It would seem that a private message addressed directly to the moderator might be a more efficient method than hoping the moderator would happen upon this post.)
