MarkARockport
Jun 20, 2019Aspirant
NetGear, Orbi Mesh WiFi
Cannot get my Orbi to download new update via WiFi from my phone. Have tried multiple times to download via the NetGear, Orbi App, from my phone, wait the required time and app states that it cannot...
ekhalil
Jun 20, 2019Master
Please try to download the software from the Netgear Support page: https://www.netgear.com/support/product/RBR20.aspx#download
Then please do a manual update using the Orbi web GUI.
- CrimpOnJun 20, 2019Guru - Experienced User
Yes, do not use the Orbi app for the download. Use a web browser to download the file and then to perform the update.
- MarkARockportJun 20, 2019Aspirant
Downloaded the file from NetGear for the update. My Mac will not open the *.img file that was zipped into the download. What to do?
- ekhalilJun 20, 2019Master
MarkARockport wrote:...... My Mac will not open the *.img file that was zipped into the download. What to do?
The .img file is the file that you need to use for the update.
- In the web GUI go to >> ADVANCED >> Administration >> Firmware Update >> Manual Update
- Click on Browse and select the .img file that you previously downloaded.
