TerjeF's avatar
TerjeF
Follower
Nov 16, 2020
Netgear orbi missing password
I bought netgear Orbi RBK50, from the store where someone had used it and returned it. Discovered that it lacks password that allows me to connect the internet.
  • FURRYe38's avatar
    So you mean the wifi password?
    If so, use a web browser and log into the RBRs web page and setup the wifi SSID name and input a new password.
  • CrimpOn's avatar
    CrimpOn
    When Orbi's leave the factory, the WiFi name (SSID) and password are set to a default which is printed on the product label (on the bottom of the router).  The web management interface login is set to "admin" and "password".  If the previous owner changed these settings, you can restore them to the default by performing a "Factory Reset": https://www.youtube.com/watch?v=cMw4ePACgc4
    Then, you can log into the management interface (http://orbilogin.net) and set them however you want.
