sandip_dstech
Dec 23, 2024Aspirant
Netgear Orbi not connecting to 5 Ghz
My Netgear Orbi RBR50 Router suddenly stopped working on 5 Ghz band. Devices can connect to its 2.4 Ghz band but not on 5 Ghz. However, the Orbi Satellite connects to both 2.4 and 5 Ghz. Please help....
Dec 24, 2024Guru - Experienced User
Might try a 30-30-30 reset on the RBR to see if this brings back the 5Ghz radio. If this fails, then the RBR would need to be replaced.
sandip_dstech wrote:
My Netgear Orbi RBR50 Router suddenly stopped working on 5 Ghz band. Devices can connect to its 2.4 Ghz band but not on 5 Ghz. However, the Orbi Satellite connects to both 2.4 and 5 Ghz. Please help. I have rebooted the router multiple times.
sandip_dstech
Dec 24, 2024Aspirant
FURRYe38 What is 30-30-30 reset?
- FURRYe38Dec 24, 2024Guru - Experienced User
- sandip_dstechDec 24, 2024Aspirant
FURRYe38 Thank you! Will try that too.
đ
Another option might be to try and load up Voxels 3rd party FW as well and see if the radio appears. Could bring it back however would have same result. If so, ya, seems like the 5Ghz may have died? đ€
