sandip_dstech
Dec 23, 2024Aspirant
Netgear Orbi not connecting to 5 Ghz
My Netgear Orbi RBR50 Router suddenly stopped working on 5 Ghz band. Devices can connect to its 2.4 Ghz band but not on 5 Ghz. However, the Orbi Satellite connects to both 2.4 and 5 Ghz. Please help....
sandip_dstech
Dec 24, 2024Aspirant
FURRYe38 What is 30-30-30 reset?
Dec 24, 2024Guru - Experienced User
- sandip_dstechDec 24, 2024Aspirant
FURRYe38 Thank you! Will try that too.
- FURRYe38Dec 24, 2024Guru - Experienced User
đ
Another option might be to try and load up Voxels 3rd party FW as well and see if the radio appears. Could bring it back however would have same result. If so, ya, seems like the 5Ghz may have died? đ€
