donalcombright
Aug 31, 2018Guide
Netgear Orbi Performance Slow
I have recently purchased an Orbi system (RBK50). I am wondering what troubleshooting I can do to enhance my network speeds?
I have FiOS gigabit, and directly connecting my laptop to the ONT (a...
donalcombright
Sep 01, 2018Guide
The ONT is the outdoor device from FiOS that converts the fiber line to ethernet, it’s not a router. I am not using my Verizon FiOS router at all. Can I still put my Orbi in AP mode?
toe
Sep 02, 2018Apprentice
You'll need something like an EdgeRouter, which can handle the VLAN/PPPoE from FiOS.
- st_shawSep 02, 2018Master
The ONT is the outdoor device from FiOS that converts the fiber line to ethernet, it’s not a router. I am not using my Verizon FiOS router at all. Can I still put my Orbi in AP mode?You'll need something like an EdgeRouter, which can handle the VLAN/PPPoE from FiOS.
I have never heard of FiOS using pppoe or VLANS. I have FiOS and neither of these are used in my area.
- donalcombrightSep 02, 2018GuideSo does this mean the Orbi will not obtain gigabit speeds in router mode? That’s upsetting.
So does this mean the Orbi will not obtain gigabit speeds in router mode? That’s upsetting.No. It just means that you cannot achieve gigabit speeds using whatever test method you are using. You reported slow speeds with your older router, so the one constant here is your test method is reporting slow speeds.
You must use a speed test that utilizes multiple parallel streams to get maximum throughput with Orbi. I just tested the throughput of my Orbi in router mode and get a 30-second average of 860 Mbps.
Put your Orbi back into router mode and repeat the speed test to the following two sites:
1. The verizon FiOS speed test site. https://www.verizon.com/speedtest/
2. The dslreports speed test site. Make sure you select "Gigabit/Fiber". http://www.dslreports.com/speedtest
See what results you get from these test sites.
