alitech
Nov 16, 2017Guide
Netgear Orbi Port Forwarding, used to work, then stopped, cant fix please help
Hi guys
Hope you can help in some way. As soon as I got the router, I got port forwarding setup just like I had on my netgear R7000. All the settings are the same pretty much. At first port forwarding worked fine, then all of a sudden it stopped. I use it for accessing plex etc.
I have been searching but I cannot seem to find how to fix the issue. I have deleted and added all the settings back. Rebooted the router a couple of times. Its been a few weeks and I am still none the wiser.
Can anyone help? I use this in Router mode. My modem is external. All DHCP happens through the orbi and I have also reserved a few IPs for specific items on the network and also to ensure that port forwarding always goes to a fixed IP.
Thanks
- alitechGuide
Upnp is turned off by the way
What are you seeing now that tells you it isn't working? What are you trying to port forward to, e.g., a Windows computer? There may be firewall settings at the endpoint that have changed.
First, go to http://www.canyouseeme.org/ and see if the port you're exposing can be seen from the outside. This tells you if it at least is getting through the Orbi. For my port 3389 it says:
Success: I can see your service on 69.181.68.10 on port (3389)
Your ISP is not blocking port 3389If I try a port number that is not forwarded canyousee me says:
Error: I could not see your service on 69.181.68.10 on port (3388)
Reason: Connection timed out- alitechGuide
Just found some time to come back to fix this. I am trying to port forward to a windows 10 computer. I have checked the firewall settings for the application I am trying to get. It is open for incoming connections.
Canyouseeme.org is reporting that the port is blocked, as I suspected. I can't seem to figure this out. It was working before and its stopped working. I cannot figure this one out. I am really annoyed about all this.
What else should I try, please?
