y_u_no_work
May 06, 2020Aspirant
Netgear Orbi portforwarding not working
I recently upgraded my router from a very old Netgear N600 WNDR3800 router to a Netgear Orbi rbr50. I had a Minecraft server that I ran on my old router that I'm trying to move to the Orbi. I am tryi...
- May 10, 2020
So turns out the porblem was the modem after all! The modem was very very old, and I don't think it got along with the Orbi very much. I upgraded the modem and now the server is working great! Thank you all for your help!
CrimpOn
May 06, 2020Guru - Experienced User
y_u_no_work wrote:I am trying to run it through port 25565 (the standard for Minecraft) and have UPnP turned off. I'm using a port checker and it says that the port is closed. I've tried restarting my router, and computer. Any ideas?!
The Minecraft server is operating, correct? Both TCP and UDP are open on port 25565?
y_u_no_work
I have the TCP and UDP option selected. My port checker says they’re both closed. This issue only started once I switched to the Orbi router.
