y_u_no_work
May 06, 2020Aspirant
Netgear Orbi portforwarding not working
I recently upgraded my router from a very old Netgear N600 WNDR3800 router to a Netgear Orbi rbr50. I had a Minecraft server that I ran on my old router that I'm trying to move to the Orbi. I am tryi...
- May 10, 2020
So turns out the porblem was the modem after all! The modem was very very old, and I don't think it got along with the Orbi very much. I upgraded the modem and now the server is working great! Thank you all for your help!
y_u_no_work
I have the TCP and UDP option selected. My port checker says they’re both closed. This issue only started once I switched to the Orbi router.
CrimpOn
May 06, 2020Guru - Experienced User
The local IP address of the Minecraft server has not changed?
