George95
Dec 14, 2019Aspirant
Netgear Orbi RB20 no longer working after switching off/on
After being switched off and on, both routers are now always stuck on a magenta light, sometimes a blue light will come on for seconds but then go back to magenta instantly. All that happened was one ...
- Dec 15, 2019Eventually got it to work after doing a factory reset, still took a while even then, purple light again but thankfully working in the end.
George95
Dec 15, 2019Aspirant
1. Vodafone Broadband Modem.
2. Pretty sure more than 90 days.
3. Yes it has always worked.
4. One connected to router and then one satellite in my room, yes.
5. I’ve been using Wi-Fi for my iPhone, Ethernet for PC and PS4, none of which work now.
Dec 15, 2019Guru - Experienced User
George95 wrote:
1. Vodafone Broadband Modem.----Which model?
You put magenta ring. Is it blinking or solid? Each mean different things. but its usually a variation of not getting an ip address. Whether its for modem-router connection or router-satellite connection.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
Again, which modem modem is it?
if you directly connect to it, does it work?
- George95Dec 15, 2019AspirantI don’t know model, not at home right now. It is always solid ring. The router is just generic one when sign up for broadband, not custom. The internet router itself is working fine, yes.
- George95Dec 15, 2019AspirantEventually got it to work after doing a factory reset, still took a while even then, purple light again but thankfully working in the end.
