Retired_Member
Mar 22, 2020Netgear Orbi RBK23 and Apple Time Capsule 4th Gen
Hi all, I just bought a Netgear Orbi RBK23 with two additional sattelites set to create a mesh network in my flat. It works very well and now my wifi extends into a bedroom that never previously had...
Retired_Member
Mar 22, 2020And for clarity, here is my setup:
Physical:
1gb internet -> internet provider's router -> Apple Time Capsule -> Orbi. Ethernet cable is plugged from the Time Capsule to the Orbi "ethernet" port. If I plug into the "internet" yellow port, internet doesn't work
Software:
Apple Time Capsule set to Airport Utility -> Advanced -> DHCP and NAT -> Router Mode "off (bridge mode)"
Orbi set to -> Bridge mode (and now I can't access the admin page at all)
Retired_Member
Mar 22, 2020I was able to get this to work with the support of the Netgear agent on the phone - thanks all
