Mrrs4
May 14, 2019Follower
NETGEAR Orbi RBK23 and NETGEAR Orbi RBK50 together?
Will NETGEAR Orbi RBK23 and NETGEAR Orbi RBK50 work together? Setup with 2x NETGEAR Orbi RBK50, and put one or two RBK23 as satelite?
May 14, 2019Guru - Experienced User
You can use the RBS from the RBK20 series on with the RBK50 series system. You can not use the RBR20/50 as a satellite.
