AyySwift
May 27, 2020Aspirant
Netgear ORBI RBK23 extremely slow download speeds???
Hey guys, last week I picked up a 3 pack Netgear Orbi RBK23 for my aprox 2500 sqf house. (This house is quite open and the concrete isn't thick). So, I set my Orbi up with my old ISP (speeds were 20/...
AyySwift
Wired and wireless both give same results with the sattelite, but full speed on the router
May 27, 2020Guru - Experienced User
What mode is the modem working in? I believe yoru modem already has a built in router and wifi. This needs to be configured for modem mode only if possible.
Has a factory reset and setup from scratch been performed since last update?
You might bring the RBS in maybe a bit closer to see if this helps any. Try 40 feet...I would try this as well, turn off one of the RBS and reboot the RBR and the other RBS. Test again...
I agree you should be seeing near or spot on speeds with 50Mbps.
- AyySwiftMay 27, 2020Aspirant
I did 2 factory resets, before and after updates, nothing worked.
Beamforming +MIMO is already on
20/40Mhz Coexistence to 40Mhz only is already done
I already tried 45-40 feet, same exact speed.
Fast roaming already off
Already tried no daisy chain ~ same issue
What I havent tried:
Disable: Armor, Circle
Enable WMM
Should I try those?
- FURRYe38May 27, 2020Guru - Experienced User
AyySwift wrote:I did 2 factory resets, before and after updates, nothing worked.
Enable WMM
Should I try those? YES
WMM should always be enabled. Disabling this would be one cause of slower wifi speeds.
Sorry, just checked settings and its already on :(
I thought it was something you had to turn on but i didnt touch it so its already on
any ideas? ~~~
