Devilking
Aug 09, 2020Follower
Netgear Orbi RBK30 Unable to set up
I purchased a RBK30 router and Satellite. I have a netgear Router/Modem and I tried connecting the Orbi to the Router/Modem and tried to set it up. Rebooted the router and then plugged in everything ...
Mstrbig
Aug 10, 2020Master
What netgear router do you have? Is that your ISP modem/router or do you have an ISP modem the Netgear router is plugged into? If the latter, I would remove the Netgear router and plug the Orbi router directly into the ISP modem.
Not sure if you purchased new or used. So I suggest factory resetting your RBK system (router and all satellites). Then try install again, using the app and following the instructions.
