Devilking
Aug 09, 2020Follower
Netgear Orbi RBK30 Unable to set up
I purchased a RBK30 router and Satellite. I have a netgear Router/Modem and I tried connecting the Orbi to the Router/Modem and tried to set it up. Rebooted the router and then plugged in everything ...
Aug 10, 2020Guru - Experienced User
If your modem has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Devilking wrote:I purchased a RBK30 router and Satellite. I have a netgear Router/Modem and I tried connecting the Orbi to the Router/Modem and tried to set it up. Rebooted the router and then plugged in everything as instructed but the Orbi APp errors out as Orbi not found. Tried multiple times but its still the same. Can I use the netgear Orbi with the exisitng router if yes How do I do it. Please help me
