bobmorrissey's avatar
bobmorrissey
Follower
Sep 13, 2019
Netgear Orbi RBK30
How does this product work with Sonos speakers? (sonos one  and sonos play) - have read that it is difficlult to connect?
1 Reply
  • Work fine if correctly configured.
    You have two options:
    1. Connect one (and only one) of the speakers by Ethernet cable to Orbi and use SONOSNET to establish the mesh network between the speakers. Select a radio channel for SONOSNET different than those used in Orbi. Avoid auto channel selection.
    2. Connect all speakers wirelessly to Orbi.
    Good luck
