jameyers4
Aug 03, 2019Tutor
Netgear Orbi RBK50 - Web certificate expired yesterday (Aug 2, 2019)
I logged into my Orbi RBK50 today - long story short - the security certificate expired yesterday. I have the latest firmware posted (just udpated some days ago) v2.3.5.30. Can someone from Netge...
SergeD
Aug 09, 2019Tutor
Same issue here...
I reset the orbi rbr50 and satellite to redolve wifi dis connections issue and got an other one with certificate expired
... too much issue in the last months for a 400€ solution....
It has worked fine between sept-dec 2018 but now .... dropping wifi , pages not loading correctly, expired certificate.... if I would know that in advance, i would have choose an other brand, really
Aug 09, 2019Guru - Experienced User
The invalid Certificate won't be a cause of your wifi problems.
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
SergeD wrote:
Same issue here...
