alfred56
Sep 18, 2018Tutor
Netgear Orbi RBK50 DDNS issue
Hi Netgear community,
I have a Netgear Orbi RBK50 Firmware V2.1.4.16 and do not think the DDNS function is updating my host at NO-IP.COM.
The service is configured with the right hostname...
- Sep 18, 2018This happens sometimes with me. I also have DDNS from No-IP.com. When this happen I just disable DDNS by unticking "Use a Dynamic DNS Service" then Apply the changes and then do the opposite. The DDNS status will show correctly after that --> xxxxxxx updated successfully at 11:01 PM, 09/18/2018
Sep 18, 2018Guru - Experienced User
- Christian_RSep 18, 2018NETGEAR Employee Retired
Hello alfred56,
Have you made any recent changes to your configs when the issue occurred?
~Christian
- alfred56Sep 18, 2018Tutor
Christian_R wrote:
Hello alfred56,
~Christian
Hi Christian and thank you for your reply.
I did not make any configuration changes.
I know it was working under previous firmware versions.
I reset everything to factory defaults and reconfigured everything and I still get that message when I check the DDNS status.
Perhaps some Netgear engineers should look into this.
Regards
Alfred56
