saeid100AspirantJan 29, 2020NETGEAR ORBI RBK50 ExtenderHiI have got Netgear Orbi RBK50 for my home solution. I am looking for two extenders. which particular extender works well with my home solution. Thanks
3 RepliesReplies sorted by OldestFURRYe38Guru - Experienced UserJan 29, 2020Adding another RBS50 would be recommended. saeid100Aspirant to FURRYe38Jan 29, 2020Thanks for your reply. if i buy new RBK53, can i use my existing satelite or router from RBk50 to merge with RBk53.FURRYe38Guru - Experienced User to saeid100Jan 29, 2020You can use the RBS from your existing system. RBRs do not work as satellites.
