aec4444
Aug 04, 2019Aspirant
Netgear ORBI RBK50 slow modem speed
I have gigabit service from ATT. When I test the speed on the modem/router AT&T supplied, I get the expected speeds (992 down, 930 up). When I test on the Orbi router which is just connected via Et...
Aug 05, 2019Guru - Experienced User
When you testing with the RBR in the mix, are you speed testing with a PC and a speedtest app on the PC or speed testing with the speedtest app on the RBRs web page?
What happens if you configure the RBR for AP mode and speed test?
Has a factory reset and setup from scratch been performed with out enableing QoS/Speedtest, Traffic Meter and Any access controls on the RBR?
FYI: @Blanca_O
aec4444 wrote:I have gigabit service from ATT. When I test the speed on the modem/router AT&T supplied, I get the expected speeds (992 down, 930 up). When I test on the Orbi router which is just connected via Ethernet cable (and all the Wifi Radios on the AT&T device are turned off), I get ~500 down, 935 up. I have run this test many times and the router from Netgear is half the speed down. Why?
These aren't speed tests on devices, these are tests on the router/modem themselves via either the ORBI App or via AT&T app.
