aec4444
Aug 04, 2019Aspirant
Netgear ORBI RBK50 slow modem speed
I have gigabit service from ATT. When I test the speed on the modem/router AT&T supplied, I get the expected speeds (992 down, 930 up). When I test on the Orbi router which is just connected via Et...
aec4444
Aug 05, 2019Aspirant
I have updated the firmware to 2.3.5.30.
I’m testing using the orbi app which is testing on the router itself. Not using speed test or anything like that.
When I test on the att router it’s 992 Mbps. When I test on the orbi 550 today.
The orbi is in AP mode.
Here is the att modem info
Manufacturer ARRIS
Model Number BGW210-700
Software Version 1.9.16
MAC Address 74:8a:0d:82:69:11
First Use Date 2019/06/25 15:16:33
Time Since Last Reboot 01:08:56:24
Current Date/Time 2019-08-05T23:05:25
Datapump Version A2pvbJ042w.d26r
Hardware Version 02001C0046004D
Legal Disclaimer Open Source Licenses
Manufacturer ARRIS
- FURRYe38Aug 06, 2019Guru - Experienced User
The Orbi app isn't giving good accurate information.
Try using Ooklas stand alone speed test app.- aec4444Aug 07, 2019AspirantThat wouldn’t be the same test unless I had a computer connected via Ethernet. That’s the whole point of the test on the router to test internet speed without any dependency on WiFi or the computer testing.
- FURRYe38Aug 07, 2019Guru - Experienced User
The built in speed test app seems to have problems. I would open a support ticket and let NG know of your experiences:
https://www.netgear.com/mynetgear/registration/login.aspx
The suggested use of a wired PC and stand alone speedtest app will be a valid test to check to ensure the Orbi is working otherwise.
Good Luck.
