aec4444
Aug 04, 2019Aspirant
Netgear ORBI RBK50 slow modem speed
I have gigabit service from ATT. When I test the speed on the modem/router AT&T supplied, I get the expected speeds (992 down, 930 up). When I test on the Orbi router which is just connected via Et...
aec4444
Aug 07, 2019Aspirant
That wouldn’t be the same test unless I had a computer connected via Ethernet. That’s the whole point of the test on the router to test internet speed without any dependency on WiFi or the computer testing.
Aug 07, 2019Guru - Experienced User
The built in speed test app seems to have problems. I would open a support ticket and let NG know of your experiences:
https://www.netgear.com/mynetgear/registration/login.aspx
The suggested use of a wired PC and stand alone speedtest app will be a valid test to check to ensure the Orbi is working otherwise.
Good Luck.
