AC641
Jan 03, 2019Luminary
Netgear Orbi RBK50 vs Google WiFi (3 devices)
Having had issues with the Netgear Orbi, specifically the inability for Philips Hue lights to work reliably and intermittent loss of WiFi from iPhone/iPad when connected to the Satellite I have had a play with Google WiFi. To replace a Netgear RKK50 (1 x Router and 1 x Satellite) I am now using 3 Google WiFi devices to cover the same house. Here’s what I’ve found after some 48 hrs and quite a lot of testing:
- The WiFi range of a single Google WiFi device is less than that of an Orbi Router/Satellite.
- The Google WiFi setup HAS to be done via the Google WiFi app (iOS or Android); the settings are all there but they’ve taken a little time to get used to. For example, assigning static IP addresses isn’t as straightforward as with the Orbi interface.
- My decision to purchase the Netgear Orbi originally was that it offered two key features for me: the facility for a Guest Network and the ability control the DHCP. The Google devices now offer DHCP control. The Google WiFi Guest network is correctly isolated and you can control what devices on the network a guest has access too.
- A big thing for me is that now my Philips Hue lighting routines work flawlessly. I have setup many test routines over the last couple of days and EVERY one has switched the lights on and off without fail. Moreover, the Hue Hub is seen over the Internet, which it wasn’t previously and I believed was due to me getting my internet via a 4G network using CGNAT (I live in the UK countryside and can’t get above 6.5Mbps via the phone line).
I’ll add to this thread in a week or so with any additional observations but so far the Google WiFi is beating the Orbi system in every department except WiFi range.
- thombeApprentice
can i just ask who your 4g provider is and can you get unlimited usage from them or is it capped ?
- AC641Luminary
The ISP is EE. My data contract is capped at 200GB at £60 permonth but that's fine for me. Having been used to poor Broadband I don't stream 4K TV and am not a gamer. I've noticed that EE is now offering up to 500GB a month. It's an interim solution for me before Gigaclear install FTTP at some point.
- thombeApprentice
yup, thought it must be EE. thanks v much
