Devil000
Oct 30, 2019Aspirant
Netgear Orbi RBK50 with 2 Satellites - Patchy / Slow Wifi performance
Hey, I have had the RBK50 around a year now and it has been amazing since day one. However in the last week or so the Wifi has been terrible. Its been slow, patchy and all round frustrating. ...
Oct 31, 2019Guru - Experienced User
If you have another router infront of the Orbi router, you might try AP mode:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Devil000 wrote:Made sure daisy chain is off.
Basically I have Sky Q with Sky Fibre Broadband. I turned off Wifi from the Sky router and connected the Orbi router directly to the Sky router. Then Orbi provides all Wifi in the house. When running setup wizard Orbi said to use Router mode rather than AP mode which I have left alone.
Devil000
Nov 04, 2019Aspirant
Hey,
I have tried all of the above apart from the AP Mode settings in your last message as my setup used to work really well so not sure why it would stop now.
Still have issues, hoping there will be a firmware release soon to resolve these issues. Is there any way to chat to Netgear?
Thanks
- FURRYe38Nov 04, 2019Guru - Experienced User
What is not working exactly if you were able to either bridge or use the DMZ/IP Pass-thru method on your modem?
Either of these methods will work with Orbi to keep orbi in router mode.
Did you power OFF the modem and Orbi RBR after making changes?
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQPlease give AP mode a try.
Devil000 wrote:Hey,
Thanks
- Devil000Nov 04, 2019Aspirant
Will check the bridge / DMZ setup tomorrow.
Everything was rebooted after changes and a full factory reset has been done since going to latest firmware.
Thanks
Let us know how the DMZ works...it should work fine if you want to keept the Orbi RBR in router mode.
