Devil000
Oct 30, 2019Aspirant
Netgear Orbi RBK50 with 2 Satellites - Patchy / Slow Wifi performance
Hey, I have had the RBK50 around a year now and it has been amazing since day one. However in the last week or so the Wifi has been terrible. Its been slow, patchy and all round frustrating. ...
Nov 04, 2019Guru - Experienced User
What is not working exactly if you were able to either bridge or use the DMZ/IP Pass-thru method on your modem?
Either of these methods will work with Orbi to keep orbi in router mode.
Did you power OFF the modem and Orbi RBR after making changes?
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ
Please give AP mode a try.
Devil000 wrote:Hey,
I have tried all of the above apart from the AP Mode settings in your last message as my setup used to work really well so not sure why it would stop now.
Still have issues, hoping there will be a firmware release soon to resolve these issues. Is there any way to chat to Netgear?
Thanks
Devil000
Nov 04, 2019Aspirant
Will check the bridge / DMZ setup tomorrow.
Everything was rebooted after changes and a full factory reset has been done since going to latest firmware.
Thanks
- FURRYe38Nov 04, 2019Guru - Experienced User
Let us know how the DMZ works...it should work fine if you want to keept the Orbi RBR in router mode.
- Retired_MemberNov 04, 2019
FURRYe38 wrote:Let us know how the DMZ works...it should work fine if you want to keept the Orbi RBR in router mode.
Why do you insist on taking these folks down rabbit holes knowing that nothing has changed but the firmware is now V2.5.0.38.
Stop wasting peoples time.
