PEFA
Mar 17, 2019Aspirant
Netgear Orbi RBK50 with Openreach ECI modem
I want to replace my BT broadband with Plusnet. I have an Openreach ECI modem (model B-Focus v-2FUb/r Rev B) and a HomeHub 5 Type A. Can I keep the ECI modem and connect a Netgear Orbi RBK50 direct...
timch
Mar 18, 2019Luminary
The Openreach modems are exactly that, a modem, so don’t need bridging. All you do is plug into the cable from the modem to the Orbi yellow wan port and set up the Orbi as PPOE with you plusnet login credentials. The reply from Furry is using his stock response but I don’t think he understood your original question. I assume he is not British as he has given several misleading responses in the past to questions about UK implementation of VDSL. Bottom line, the Orbi works exactly as designed with the Openreach modems.
schumaku
Mar 18, 2019Guru - Experienced User
timch wrote:
The Openreach modems are exactly that, a modem, so don’t need bridging. All you do is plug into the cable from the modem to the Orbi yellow wan port and set up the Orbi as PPOE with you plusnet login credentials. T... I assume he is not British as he has given several misleading responses in the past to questions about UK implementation of VDSL. Bottom line, the Orbi works exactly as designed with the Openreach modems.
Agree ref. the xDSL part. Does this also apply to the FTTx implementation in place over there, and does Orbi support DHCP option 60/VCI and/or DHCP option 61/MER as required by some connection or do I have this wrong in my old grey cells?
