murfjr3
Feb 14, 2019Aspirant
Netgear Orbi rbk50
ok please bear with me ..
i have centurylink fiber (GPON) with a gig service
i dont have a large house but im useing centurylinks modem/router c2100z and my wifi signal sucks (hopeing orbi wi...
Feb 14, 2019Guru - Experienced User
This would be a double NAT condition which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
i dont have a large house but im useing centurylinks modem/router c2100z and my wifi signal sucks (hopeing orbi will help)
i am looking into getting a orbi rbk50 but can i just get rid of my centurylink modem and plug right into orbi
i only have a ethernet cable going from the ont to there modem i am not super good with all this new stuff but hopeing someone can help me
thank you in advance
murfjr3
just curious does anyone know of any other way to get a better signal or is getting a obi the best way
and useing clinks modem and connecting it to orbi does that lessen the signal ?
