emstelon
Oct 01, 2019Aspirant
Netgear Orbi Rbk50
I have the Netgear Orbi RBK50 behind the Ziggo modem, which is in bridge mode. in the beginning the wifi speed was high. almost as much as the provider delivers. e.g. 186Mbps of the 200Mbps supplied....
Oct 01, 2019Guru - Experienced User
What devices are you using to speed test?
Do wireless and wired speed tests compare the same or differently?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Has a factory reset and setup from scratch been performed since last FW update? Power OFF The ISP modem for 30 seconds then back on then walk thru the setup wizard after doing a factory reset?
