emstelon
Oct 01, 2019Aspirant
Netgear Orbi Rbk50
I have the Netgear Orbi RBK50 behind the Ziggo modem, which is in bridge mode. in the beginning the wifi speed was high. almost as much as the provider delivers. e.g. 186Mbps of the 200Mbps supplied....
emstelon
2.3.5.30 firmware
Arris TG3492LG is the modem.
The measured speed is with the Samsung tablet. Wired I get 250 Mbps download and 25 Mbps upload on the computer
Home is 1100sq ft. Have satellite on the second floor not even 30 ft away from the main router on the 1st floor.
I don't know if the neighbors are bothering me, how should I read a WiFi analyzer? See screenshot
I tried to change the channels and / or switch them off automatically.
2.4 GHz is set to automatic and 5 GHz to 36
Beamforming, MIMO enabled.
Without rebooting Orbi and / or modem, speed became worse.
WMM was already on.
Do I have to restart the router and modem after these actions or should the change be immediately noticeable?
You say: Try disabling the following and see: Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20 / 40MHz Coexistence only at 40MHz.
Where can I find Armor, Circle, Daisy Chain?
I can only switch coexistence 20/40 on or off.
There has been no factory reset after updating firmware.
