Josser
Dec 03, 2019Tutor
Netgear Orbi RBK53 to Centurylink Router C3000z
Have an Orbi RBK53 system coming in. Can I hook the Orbi router directly to the Centurylink C3000z router for setup and use?
- Retired_MemberDec 03, 2019
Josser wrote:
Retired_Member wrote:why do you want to use Centurylink C3000z router?
I thought I had to keep it to use Centurylink wifi. Can I just get rid of the Centurylink Router and replace it with the orbi? Connect the Orbi to the CenturyLink modem? Is there any special process to follow if this is possible except normal installation?
I believe this question was directed to me.
Yes, the Orbi is a router plus any Sats you may have.
Retired_Member
Dec 03, 2019why do you want to use Centurylink C3000z router?
Josser
Dec 03, 2019Tutor
