townsmcp2
Jan 04, 2020Aspirant
Netgear Orbi RBK53 upnp map not showing on firmware 2.5.1.8
As the subject says, with firmware 2.5.1.8 I can't see the upnp table in "Advanced - Advanced Setup - upnp" in the website, the page stays blank. the reason I'm trying to see what ports are setup is...
CrimpOn
Jan 04, 2020Guru - Experienced User
UDP Port 123 is the port used by the Network Time Protocol (NTP). Orbi uses NTP to set its own clock. My guess is that forwarding UDP port 123 to a different host would interfere with the Orbi knowing what time it is. In fact, every device on the network that knows about "time" probably sends requests out port 123 and expects responses on port 123. If those get "forwarded" to only a single host, then nothing on the network will know what time it is.
Or.... I could be mistaken. I often am.
townsmcp2
Thanks. I guess that answers the UDP port issue for me (the O2 Boostbox seems to be working ok with the other ports set).
The UPNP map issue would still need sorting - CrimpOn are you on the same firmware and see the same issue not showing the mapping?
- CrimpOnJan 04, 2020Guru - Experienced User
I have not created any UPnP maps (not even sure what that means). My page looks like this:
