townsmcp2
Jan 04, 2020Aspirant
Netgear Orbi RBK53 upnp map not showing on firmware 2.5.1.8
As the subject says, with firmware 2.5.1.8 I can't see the upnp table in "Advanced - Advanced Setup - upnp" in the website, the page stays blank. the reason I'm trying to see what ports are setup is...
townsmcp2
Thanks. I guess that answers the UDP port issue for me (the O2 Boostbox seems to be working ok with the other ports set).
The UPNP map issue would still need sorting - CrimpOn are you on the same firmware and see the same issue not showing the mapping?
CrimpOn
Jan 04, 2020Guru - Experienced User
I have not created any UPnP maps (not even sure what that means). My page looks like this:
