snow999
Mar 14, 2018Follower
NetGear ORBI RBK53
Hello, I'm about to buy an Orbi RBK 53 home wifi extender with 2 satelites, but I may need to add more satelites. My house is large about 6000sq feet and extends over a fairly large area. My q...
Starbucky
Mar 14, 2018Apprentice
It depends on how many devices you have. If you have wired devices then they can take the extra ISP bandwidth. Also in theory it's 866+400, where you add the capacity of both radios. I've seen some of my stationary wireless devices jump between 5 and 2.4 also depending on other mobile wifi clients roaming and I guess interference/quality of signal fluctuating. If you have many devices simultaneously using the WAN then more more bandwidth would typically be better.
