ancen
Oct 06, 2021Aspirant
Netgear Orbi RBK852 - Weak Satellite Signal
Router Netgear Orbi RBK 852 AX6000 operating in router mode. Size of home: 2000 sq ft (3 story house) Distance between router and satellite: +/- 36 feet and satellite is using wired backhaul. Firm...
- Oct 10, 2021
I just added a new satellite and place it at the center of the house. It solved the problem!
I was afraid the signal is going to overlap, but it seems everything is normal until now.
Thank you!
Oct 06, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
Distance between router and satellite: +/- 36 feet and satellite is using wired backhaul.Firmware version: V4.6.3.16_2.0.51
2.4Ghz Channel: 11
5.Ghz Channel: 44
Enable 20/40 Mhz Coexistence checked
CTS/RTS threshold both set to 500 for 2.4 and 5ghz
Preamble mode set to automatic for both
Problems:
Router is placed at the front of 3rd floor area, and the satellite is placed at the back of the 2nd floor area.
My main bedroom is exactly on the top of my satellite area is getting a weak signal and frequently get disconnected.
It feels that the signal cannot "climb" to the top floor.
Any clue on what to check? I tried placing the satellite in my main bedroom with wireless backhaul, got the poor status and frequently got disconnected.
