ancen
Oct 06, 2021Aspirant
Netgear Orbi RBK852 - Weak Satellite Signal
Router Netgear Orbi RBK 852 AX6000 operating in router mode. Size of home: 2000 sq ft (3 story house) Distance between router and satellite: +/- 36 feet and satellite is using wired backhaul. Firm...
- Oct 10, 2021
I just added a new satellite and place it at the center of the house. It solved the problem!
I was afraid the signal is going to overlap, but it seems everything is normal until now.
Thank you!
ancen
Oct 10, 2021Aspirant
Thank you!
- FURRYe38Oct 11, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
