S65's avatar
S65
Netgear Orbi RBR20 Compatible Satelite
I currently have 2 satellites with my RBR20 router.  They work fine for inside my home which is a one story 1,940 square feet.  The problem that I am having is that I have an outdoor television on my patio which is getting the wifi signal, but I am experiencing a good deal of buffering.  Is there an outdoor satellite that is compatible with my system.  What would be a solution to my problem?
  • plemans's avatar
    The RBS50Y is outdoor rated and compatible.
    • S65's avatar
      S65
      Thanks so much for your prompt reply.
